Well my engine builder and I have been having some very interesting conversations on this build. He is an old school pulling truck guy. We agree, detonation on pump gas is what will know will knock the bottom end out of this build......So in the interest of allowing a bigger tuning window, we are considering dropping to 8.5:1........
As far as E85 goes, I could go that route as it is available near me.....My issue, my carb guy doesn't do E85, or blow thru.....So that leaves me with a big problem and I will need to find a carb shop I can work with. EFI is not an option due to rules. These things don't tune themselves. Thumper has been great at helping me dial in my junk over the years. I will get back to you all on that one.....I need to research more, because I think your right as far as tuning goes, the E85 has a bigger window and I don't need an intercooler, but also because I do not have the room for a bigger radiator and making this kind of hp on my tiny bracket setup may not be all that cool in +90 heat....My fuel pump is good to go already upgraded that this past summer....
https://www.e85carbs.com/BlowthroughE85.htm
Here is my one other big problem with E85, what engine oil do I have to run. I was told Brad Penn turns to jello using that fuel. I haven't used anything besides Brad Penn or VR1 since I started racing....
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
