[quote=RapidRobert]^^^ I remember that build/article! What apps would a person want to use a solid trans mount? I have one. [/quote
I can't think of one. If you look at the middle mount of a two piece drive shaft it will tell you how much force is there, not much. Big rubber mounted bearing on a "P" stand held at the bottom with two small bolts.
I bet there is a whole lot of members here that go to take a tranny out only to find their mount has long since been broken and just sitting there......been there, done that, eh?
