Originally Posted by 440mopar
Originally Posted by BradH
My last comment / suggestion, which I'm sure overlaps w/ others' feedback above:
1. Use some type of speed controller if the grinder is limited to ON/OFF; you can even use a cheap light rheostat from Home Despot or what someone else mentioned from Harbor Fright. Regardless, you have to be able to slow the grinder speed to have some level of control
2. Use 3/8" OD sanding rolls to limit the amount of material being removed; get 60 or 80 grit, not the finer grits which tend to be more for surface finishing
3. Mark off where you think you need to remove material
4. Wear safety mask & goggles
5. Take your time --> sawzall
Sorry, but I have a few more questions. I just want to be sure I do this right. So I can use sanding rolls (like those that came with my Dremel) rather than a metal bit or in conjunction with a metal bit? Either way I'll have to try and get a long stem metal bit and/or a long stem bit for sanding rolls as mine are all short stem. I was going to use a Mikita rotary hand grinder I borrowed from a friend but it is single speed and it does seem pretty powerful so I will have to pick up a speed controller as well. Could a Dremel be used to do this or is it not powerful enough for this kind of job?
I don't know that a Dremel is going to be the best tool for the job. The cutters are very small diameter and the sanding roll setup a Dremel uses will wear out far too quickly. The Makita with an inexpensive speed controller would allow for using "Tootsie rolls" on a shaft that will both last longer and enable you to reach farther into the pushrod tunnels to do the work.
