Maybe the Lodi area is exempt from the VOC regs that affect the Bay Area, L.A. County, etc or maybe it's statewide now.
Used to be tiers depending on population, CARB & bureaucracy level.
Call the local paint jobber and see if you can get solvent-based paint or if they'll only sell waterborne.
Solvent-based is less expensive & easier to work with in most respects.
