Originally Posted by beezer
If you put your bit bike on the back end of your trailer you might not have enough tongue weight and that would cause your trailer to sway , Not a very fun ride with a car and bike on behind you.
Bike weighs 200 pounds. Doubt that would make any issue.
That said, that hitch Mr P body showed me says not to be installed behind a pull behind trailer. So it pretty much has to go on the tongue
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
Best so far, 10.32 1/4
1.41 best 60 foot
6.56 at 104.17
