something is wrong, changing to a 904 from 727 should be a good gain. Anything you pick up in the 60 should be doubled in the 1/4. IF you pick up .10 in the 60' you should be picking up .20 in the 1/4.
As already mentioned, look at the fuel system and other things... but id say its the converter.
you have experience with cars, you know
Something is wrong, id take the converter out and get it to a reputable builder and get it looked at. Your leaving a lot of ET on the table.
