Originally Posted By QuickBpBp
Originally Posted By MoparMike1974
I think these can come from any early car with the smaller 4 headlights. B & C bodys would be a good source.
Not really true. 1970 and older are different part Numbers and 71 Plymouth E-body is different assembly than 71 Plymouth B-body (different rings). I did not check and see if 72 were still the same. I have 3 of the correct 4 so far. I will check another spot on Monday and get back to you...
Thank you.
