In one of the pics you can see the added rubber bumper on the frame rail that is touching the axle, so no I cannot bounce the car up and down as there is currently no downward motion possible.
There are rubber bumpers inside the coil spring as well, top and bottom. The distance between those as it sits right now is 6".
I was kinda thinking about air bags inside the springs, or different springs of course.
codfish
