I just bought a set of split mono leafs and caltrac bars for my cuda that I'm in the middle of installing. I put the front caltrac bar bracket on the front of the leaf spring and when I go to put the front spring hanger over the bracket, I have about 1/8" of play side to side and only three threads showing on the bolt. Is this normal? Stock factory spring hangers. I didn't tighten anything down, but I find it hard to believe that the spring hanger is meant to be cranked in until it is tight and there is no play.
I would not want to crush that I would give Calvert a call first thing in the morning it might be something as simple as a couple washers and a longer Bolt
