7500 rpm during the run, 7800 rpm limiter.
The crank pulley that may work for me is 5.3 inch diameter, so i need a reasonably priced alternater and pulley combo, a one wire if possible. Space MAY be an issue, so if there are multiple choices smaller is better.
I have mechanical fuel injection on alkys, the only draw for the most part is ignition, electronics, waterpump (mezuire) and a fair amount of cranking to get fuel back in the lines each time i move in the staging lanes.
Also battery recomendations, agm type to save a little weight over the 43 lb optima i run now.
