Originally Posted By RATTRAP
What are you using for clutching behind that 572 ???
[quote=Old School]It's 588 cubic inches. I use a McLeod dual disk clutch. I expect zero problems with it
What RPM are you going to shift at ? I hear a duel clutch will not be able to handle a higher RPM shift, say around 7800 to 8000 RPM. Anyone else want to chime in!
