Originally Posted By 340Cuda
Originally Posted By gtsdude
I used this one, just remember its the camshaft you are moving, not the crank like this one is made for. If you want 4 degrees advance, get a 2 degree key.
I have a belt drive now and don't have to deal with this but cam timing is based on 720 degrees. So a 4 degree key will affect the Intake Lobe Center 4 degrees. Correct?
That is correct as long as it is a 4 degree cam key not a a 4 degree crank key you are using as a cam key.
