In case you have moved or changed sensors or even if you haven't, its a good idea to check with timing light after getting her running.
First check timing marks for accuracy with the positive stop method. Then put a light on idling and see what you have. Ideally set up a "timing tune" with timing fixed at something like 15 degrees and verify that is what you have with a light.
