What engine are you using these on? Reason it matters is RPM range. If they are on a high displacement stroker that doesn't need to rev too high, maybe OK. On a smaller engine at high RPM maybe not.
Also, what does Comp recommend for that cam? Using their recommended spring would be a good idea... or at least compare specs to what you have on the heads now.
