I've had an issue for some time now with the front end of my car wearing the outsides of the tires. I've had it aligned twice in the last two years, yet the wearing is getting worse. From the printout I got comparing the two previous years camber and caster have stayed the same, so I think it's more a less a problem of not being aligned to a spec that doesn't cause tire wear. Problem is, I have no idea what values to ask for and it's obvious whatever factory spec is it isn't working.
Need some advice before replacing the front tires again... Thanks guys...
