Not sure if this helps, but I am using the Bouchillon cable kit. It uses a spring to pull the lever forward and the cable to pull it back. Ideally, the factory setup is the way to go. But if you are like me and have different intake, carb, efi or transmission, a cable is the only solution that has a chance of working. Craig https://drive.google.com/drive/folders/0ByFJ9dE-12AVeHhhNUNISExkRUU
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
