Quote: My front end is very bastardized. Stock front clip, DARE K-Frame (on it when I bought it - I didn't know), Magnum Force tubular uppers (non-adjustable), Stock LCAs, LRT steering arms, Flaming River Pinto R/P, Aldan coil overs.
Looking at the vids - the wheels are definitely toeing out when it lifts them in the air.
So - if I set the toe at ride height +1" - do I set it at 1/16" in?
The negative caster I think may be the best it can get - not sure. I may need adjustable UCAs
Yes set the toe at 1/16 in at 1" up on the body. I assume you just made a error in saying caster instead of camber but you would be better off with adjustable UCA's
