Ok, it's an A body not a B body but maybe it might get you thinking. I don't have wipers so I recycled the hole, but if you used black nylon Racehose you could squeeze the hose thru the fresh air grille.
That fuel pressure reg location ( fire wall) won't pass tech where I'm at. Again, lots of 90* fittings are not a good thing in any fuel system.
