I was talking with Craig Hopkins at the AMD Installation center a couple months ago. He said the AMD hinges are good but found something about the angle a bit too tight to make door adjustments easier. He recommended rebuilt if you have a good core set to use. If not the AMD ones would work but may require a bit more time to get things properly lined up.
