Did you gasket match the manifolds ? the last set I worked on the openings were almost an 1/8" smaller than the gasket which is what the heads were matched to.
I have a manifold that Dwayne worked on for a low deck ... and an acid ported 70 383 intake ... plus a set of extrude honed, jet hot coated A body 383 Exh manifolds ...
