Andrewh without tearing everything apart it looks like i found where it may be going........because its a real vcode i think it was going to the idle soleinoid???it is disconnected i can see it taped up so thats probably it.now it seems that i have a 2v drop in the blue wire somewhere. what would be the easiest way if there is one to figure where the drop is coming from?
