the cam is 267/275@50 .675/.675 on 106. I think the cam may be on the small side for what i'm doing. thanks for that info on t ram and cam size. I am most concerned with going fast in the upper range, but may drive to a car show or two. Do you think it would be drivable enough for that with 750's? maybe 10 mile radius.
Absolutely. If you get the issues noted above sorted out, you'll wish all your stuff had a tunnel ram.
BTW, long before it happened, I was told all engines would basically have a TR manifold. Was I was told is correct. Most everything today that is a V-8 layout has a TR on it. They just laid it down to get a hood on it! One of the places that EFI helped (think about the old max wedge crossram stuff).
