I got so fed up trying to set up an old Donovan gear drive I finally tore it off and installed a good chain set !! It would have been really simple if the idler gear had been the same size as the crank gear but it wasn't so if you turned the engine over two revolutions, the timing marks no longer lined up !! Anyhow, I figured it was overkill for my build anyway!
