If you raise the engine, keep in mind that the drive train angle will be impacted. Just something else to have to deal with.
On mine, I moved the pass shock over about 3/4" and made a notch in the shock tower rather than beat it into submission. I still have to loosen the pass mount and jack the engine up to get the valve cover off.
Master, again and still
