You can buy the tools to measure inside the valve guide holes if you want to, Powerhouse tools sells them as a kit. Then all you would have to do is take a set of calipers and measure the valve stems. Subtract the two numbers and you have your clearance.
If you don't have the tools you can just take the head to the shop and have them measure one or two valve guides while your standing there.
