Quote: You don't need to use a drill, just use a speed wrench and an extension. If the oil pump is properly lubed then the pump will prime within just a few quick spins of the wrench. I can get 60 psi of oil pressure when turning the pump by hand which is plenty to prime the engine.
Same here as I have done it many times with a speed wrench or a ratchet on an ext turning by hand. Ron
