I, as well, have always used a speed handle for engine priming. Your problem is demonstrating why it is a better solution. It is easy to turn the speed handle to get oil to pump. Plus, with the speed handle, you get a feel for what is going on - you should have a smooth motion through each revolution. You will feel if something is wrong, such as metal or grit in the system, which you would not feel with a drill motor.
Ryanf, if it doesn't turn easily, something is wrong! Don't get a bigger drill, you will just make things worse. Find out what the problem is.
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
