Looking for my broadcast sheet. 1968 Hemi roadrunner.
RM21J8G119670
Also missing the original block and trans.
Block should have the following numbers 8G119670. This stamping is located at the back of the engine where the bellhousing would bolt into the block at the 12 o'clock position. Please note there is no machined pad like the 1969 and up engines, just the numbers on the rough cast surface.
The numbers 8G119670 also should be on the machined pad located on the transmission
