Mike F you should have no issue reaching your power goal.A peak rpm would be nice about 5800-6200 rpm with the cast piston.
Now an update,the first set have been in the works for a customer's engine and should be here hopefully in a few days.4.310 bore size with 1.920 C.D. w/valve notches.1/16 ring package and stock pin size. Weight saving of about 100 grams over stock piston. This will be the standard piston exc bore size which will be available in +.030,+.040 and +.060.Standard C.D will be 1.930 for -.002 deck @9.980. Depending on cyl hd cc's,a.040 head gasket and bore size this should be a true 9.3 to 9.6 -1 comp ratio.Perfect for pump gas w/iron cyl hds.
Pics and price soon.Thanks for the input!
