Depending on your hose locations, I put a 4 core from a 1974 1-ton dually that is 26 inches into my 1971 Demon. With a little modification to the core support it bolted in using stock mounting bolts and locations. Stock fan shroud fits in as well.
Ur picture shows a flex-fan..
I would dump that @ the earliest possible time. A buddy used a flexfan and a blade broke off cut his upper hose and cut into the radiator. A flexfan may be acceptable for a low rpm street application but not in a high performance engine that revs past 5K rpm..
Just my $0.02...
