Thats 1.186 hp per cube.. thats not much.. as a rule strokers EAT duration and the lift is lacking.. and a 850 is a bit small on a big CI engine of that nature.. at what RPM do it make the peaks EDIT whats the use of this engine... and I assume this was on pump gas
