What do you mean by externally adjustable slots?
ya , what externally adjustable slots ??? .
You should be able to pry up the reluctor , 2 screwdrivers 180* apart against the housing and under the reluctor , mark it first so you put it back correctly.
Mallory sells a kit with different size spoons to adjust the amount of mechanical advance , I di it but don't remember if I pulled it apart , someone elses engine about 3 years or so ago , I have CRS now ...
