Project Orange Monster #4 is underway
This motor will be a RB 505ci with E RPM heads, hyd roller, Indy dp intake, 3:23 gear 3450 pounds with me in it. 90% street driven
What stall would be good for this combo??
3800 flash works well on the street with 3.23's...and is tite enough at 60mph for some mpg etc..you won't loose the burn out contest...get a name brand. Call your specs in.
Thanks Barnstorm
Thats what the boys at PTC said as well
