And with all that said, my 70 LA car which has ECS had an after market NOX system put on that from the booklet was mandatory by the state of California.
LOL - back in the day when a car changed ownership you had to install a NOX kit to register your car. It's just a vacuum advance retarder. Cars with multiple carbs or cold air induction were exempt.
Today the NOX upgrade isn't needed because the cars older than 1975 are smog check exempt.
