Quote: I haven't ever had the dash completely out of my car before. The stock steering column has its own supports or does it attach to the actual dash? Basically I want to know if the stock column could be used with a fiberglass dash. Thanks!
The column mounts to the dash frame.. a minor bit of work you can mount it to the firewall at the bottom of the windshield area
