I have the first one and last one in your list. I use them both. The teeth are more fragile on the double ended cutters, but I find the effort to cut through the top layer to be a bit less. I also finnd the double ended cutters work well in areas where you can get a good center punch, and the spot weld is pretty smooth (as not to catch one of the teeth).
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
