Why? Where they not built off the stock frame rail?
I could build a 2X3 box tube that would look closer to stock than that... the upper arm mount doesnt look stock either
Murder nova looks furthest from stock for sure, but it still started life as a stock nova frame rail. Now he has relocated the suspension mounting points and boxed the frame and many more things. Look at any of the stock suspension classes and you will see the same thing, lots of mods.
And you are allowed to race your rampage in our no prep race here, just needs tags and reg. and inspection if your state has it. And I am sure a drag week car wouldn't have a problem with 30mi cruise. 29/10.5 inch slick or 30 inch radial only tire rules. Should be a few heavy hitters coming from ny.
Brett Miller W9 cnc'd heads STR Chassis fabraction
