I can't see this being a PCM as everything seems to work. Just can't get a spark out of the coil.
first thing I would check is the ASD( auto shutdown relay) If it is good then I would replace the PCM.. I had one PCM fail that threw every code in the book and I had one fail that didnt throw any codes.. the one that didnt throw any codes was driven one night parked and the next morning it would not start, didnt have any spark.. The mechanic that worked on it replaced crank position sensor, the cam position sensor, the coil, the ASD and could not fix it.. I talked to two other mechanics to see if they had any Ideas they all said that it couldnt be the PCM.. Against all their advice I went and bought a new PCM installed it and it fired right up..
