So if my oil pressure at hot idle is 31 psi and 63 psi at cruise should I try using the 10w30 or 10w40?
If I use a thinner oil I may have to keep the high pressure pump since my cruise pressure is 63 Psi. Changing the spring in the pump shouldn't change the idle pressure.
