Adjust the cyl. select to 4 cyl and then back to 8 and also make sure that there is no timing being pulled out for what ever reason. To bad its not a 7al3 box. I've screwed up installing more of them than the guys a scumitt even see go through the doors. Its always the same thing too! You would think I would remember that by now.
Back in the swing of things at Painless again! Great to be back!
