I have frame rail springs and TTI 3" to the tail pipes. Bolted right up to the rear seal bolts. I used 2 1/2" tail pipes. I wanted to try turn downs at the strip but It was too close to rear end housing. Maybe I didn't look enough because it was a while ago.
