Backing up is the WORST THING you can do... unless you roll a GOOD 3' back out...you need to reset the sprag ... dont worry about the best or worst RT... always try to find your average... if your average has a wide spread... find a practice tree to play on
Our staging lane is not straight with the track it has a very sharp right hand turn to get on the track and where I am backing up is almost into the burn out box. It is not into the starting line I am still 20 feet from the starting line. Just backing car to line up because of the spool.
"A goal without a plan is just a wish."
