Does anyone make a dropped center link for an E Body to give more oil pan clearance?
How much do you need? You can adjust the motor a little higher by loosening the motor mount, jacking the motor slightly and re-tightening before you release the jack. Adjust both sides to your liking. I just did it after a header install only left 1/4" clearance on the passenger between header and the side if the engine bay. I put it to little more than 1/2"
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
