you want a shop that can balance up to 10,000 RPM shaft speed, for a TKO application
Mike
Why?
That would be 8200 rpm engine speed in 6th and there is no way your drive shaft will ever see 10000 rpm in any other gear (or in 6th for that matter).
What about a .50 OD application?...
Did the TKO600 come with a .5 OD ratio?
I see a .82 and a .64, no .50
What road speed would you be doing at 5000 engine rpm in OD? or 6400 engine rpm?
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
