Re: Help with Drive Line Vibration
[Re: Mopar_Mudder]
#1439459
10/29/13 06:00 PM
10/29/13 06:00 PM
Posts: 18,165 Mass
DAYCLONA
Mass
I'd ask Inland Empire what there balance speed is when they balance a shaft,...suprisingly most shops only balance up to 3500 RPM,....you want a shop that can balance up to 10,000 RPM shaft speed, for a TKO application
Mike
Inland maxes out at 3500 they said, not that they balanced it that high.
Called a couple shops around here and most balance at 500 maybe 2500. They never heard of balancing that high
Keisler balances all their shafts at 10,000 RPM, they are one of only a handful of shops with the capability, most shops are only using conventional lathes to balance their shafts, very few actually invest in dedicated balancing equipment
Mike
