some of the Lexus V8s in the 1990s had power steering pump return flows running radiator fans with hydraulic motors
aside from the danger from leaks that was an interesting idea
If you had to deal with those hydraulic fans and associated leaks you would not find them very interesting. Those systems were such a mess some people would come in with a drawing of the hose routing to describe what they wanted. We knew what it was immediately.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
