Youi can use the AMC lifters with standard ball/cup type Mopar pushrods, or with oil thru Chevy type pushrods.
Thanks for the info. That is what I was looking for.
Just so you know... NEVER did the MP or stock AMC
lifter have the EDM hole to feed the roller face...
the AMC lifter had the hole to oil the PR... so
if you have the bottom EDM hole it was put in a lifter
afterwards.... the EDM process didnt exists back when
AMC was around... so if its a AMC type lifter its
a aftermarket lifter that has the PR holing hole and
had the EDM hole added(or they made a new lifter that
has the PR hole and EDM hole)
EDIT
MOST guys call the push rod hole type of lifter a
AMC lifter(which in all rights was) for the mopar
family engines
