The basics of E-body hood hinge ID-
1970: teeth style; narrow top strap; all same size rivet on peened side. They had a couple minor variations in the base up stop- 1. none 2. welded on tab. 3. stamped in base. Also two different style short straps over the teeth area were used.
1971-72: teeth style; wider top strap; rear rivet on top strap is larger on peened side. Late ones started using '73-4 style base with the slider slots not used.
Rick
What does narrow top strap vs wider top strap mean? what part is that describing?
Shawn 70 AAR
