It IS clearly spelled out! Fourth line down from the top, there are two numbers listed under CARB. That would be three boxes in from the left side of the sheet. What are the two numbers?
OK he finally found his sheet. The CARB code is 36.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
