Chris, just to clarify what I said, I was thinking that you were trying '67-70 B-body pedals into an E-body so it would help if more specific on what year parts you have. The upper bracket, or doghouse's are different for B and E bodies, pedals (not including the doghouse) from a '71-74 B-body will fit right into your E-body doghouse, auto or stick but its a little tough to do in the car as the OC spring will give you fits if its your first time doing it. If the trans is a '71-74 B-body, that will fit also. Sorry if I gave you bad info.
